Philco 118x floor model restoration
Yes it is, and also in many Philco radios where low ohm negative bias network is employed between Cassis and Negative.
Philco 118x floor model restoration - by Foose - 11-05-2017, 04:02 PM
RE: Philco 118x floor model restoration - by morzh - 12-03-2017, 07:17 PM
The speaker table error?
Philco 70 antenna lead
