Sorta newbie 38-690 low volume
Your FC volages are good, they are supposed to be around 80V and 40V.
In addition, these pots have no way to influence the FC voltages.
Sorta newbie 38-690 low volume - by Hot Rod - 11-29-2017, 09:35 PM
RE: Sorta newbie 38-690 low volume - by morzh - 11-30-2017, 12:22 AM
RE: Sorta newbie 38-690 low volume - by Hot Rod - 11-30-2017, 01:46 PM
RE: Sorta newbie 38-690 low volume - by morzh - 11-30-2017, 02:08 PM
RE: Sorta newbie 38-690 low volume - by Hot Rod - 11-30-2017, 07:45 PM
RE: Sorta newbie 38-690 low volume - by morzh - 12-01-2017, 12:15 AM
RE: Sorta newbie 38-690 low volume - by morzh - 12-01-2017, 12:13 PM
RE: Sorta newbie 38-690 low volume - by Hot Rod - 12-01-2017, 01:08 PM
RE: Sorta newbie 38-690 low volume - by morzh - 12-01-2017, 04:36 PM
RE: Sorta newbie 38-690 low volume - by Hot Rod - 12-03-2017, 05:50 PM
RE: Sorta newbie 38-690 low volume - by morzh - 12-03-2017, 07:20 PM
RE: Sorta newbie 38-690 low volume - by Hot Rod - 12-03-2017, 07:37 PM
RE: Sorta newbie 38-690 low volume - by morzh - 12-03-2017, 11:24 PM
RE: Sorta newbie 38-690 low volume - by morzh - 12-05-2017, 09:33 AM
RE: Sorta newbie 38-690 low volume - by Hot Rod - 12-05-2017, 07:44 PM
RE: Sorta newbie 38-690 low volume - by Hot Rod - 12-05-2017, 07:46 PM
RE: Sorta newbie 38-690 low volume - by Hot Rod - 12-05-2017, 09:28 PM
RE: Sorta newbie 38-690 low volume - by morzh - 12-06-2017, 12:03 AM
RE: Sorta newbie 38-690 low volume - by Hot Rod - 12-06-2017, 01:45 PM
RE: Sorta newbie 38-690 low volume - by morzh - 12-06-2017, 02:26 PM
RE: Sorta newbie 38-690 low volume - by Hot Rod - 12-07-2017, 08:37 PM
RE: Sorta newbie 38-690 low volume - by morzh - 12-07-2017, 08:46 PM
RE: Sorta newbie 38-690 low volume - by Hot Rod - 12-07-2017, 09:47 PM
RE: Sorta newbie 38-690 low volume - by morzh - 12-07-2017, 11:57 PM
RE: Sorta newbie 38-690 low volume - by Hot Rod - 12-08-2017, 01:19 PM
RE: Sorta newbie 38-690 low volume - by morzh - 12-08-2017, 02:39 PM
RE: Sorta newbie 38-690 low volume - by Hot Rod - 12-09-2017, 12:21 AM
RE: Sorta newbie 38-690 low volume - by morzh - 12-09-2017, 11:26 AM
RE: Sorta newbie 38-690 low volume - by Hot Rod - 12-09-2017, 02:39 PM
RE: Sorta newbie 38-690 low volume - by morzh - 12-09-2017, 04:01 PM
RE: Sorta newbie 38-690 low volume - by Hot Rod - 12-09-2017, 08:04 PM
RE: Sorta newbie 38-690 low volume - by morzh - 12-09-2017, 09:37 PM
RE: Sorta newbie 38-690 low volume - by Hot Rod - 12-10-2017, 08:01 PM
RE: Sorta newbie 38-690 low volume - by morzh - 12-10-2017, 08:23 PM
The speaker table error?
Philco 70 antenna lead
There are currently 6894 online users. [Complete List]
» 2 Member(s) | 6892 Guest(s)
