Attaching Grill Cloth to Cabinet Philco 38-12
I've just clipped off the staples with wire cutters to the correct length and then tapped/hammered them in by hand. Its a little tricky holding it and tapping on it to get it in but it doesn't take much to get it into the wood enough to hold the cloth and frame.
RE: Attaching Grill Cloth to Cabinet Philco 38-12 - by klondike98 - 12-03-2017, 07:30 PM
There are currently 4543 online users. [Complete List]
» 1 Member(s) | 4542 Guest(s)
