Philco 41-250 Advice Please!
So probably a good place to start is a legible schematic. You can find it here:   http://www.audiophool.com/Philco.html  The Rider's stinks for this set. The 84 tube is the rectifier and with the tube removed you should see about 500vac from pins 2 and 3. Across 1 and 5 about 6.3vac.
Philco 41-250 Advice Please! - by Mountaineer - 11-30-2017, 02:28 PM
RE: Philco 41-250 Advice Please! - by morzh - 11-30-2017, 02:46 PM
RE: Philco 41-250 Advice Please! - by Hot Rod - 11-30-2017, 08:13 PM
RE: Philco 41-250 Advice Please! - by klondike98 - 11-30-2017, 08:16 PM
RE: Philco 41-250 Advice Please! - by Hot Rod - 11-30-2017, 08:43 PM
RE: Philco 41-250 Advice Please! - by Mountaineer - 12-04-2017, 09:05 AM
RE: Philco 41-250 Advice Please! - by Radioroslyn - 12-04-2017, 01:32 PM
RE: Philco 41-250 Advice Please! - by morzh - 12-04-2017, 07:20 PM
RE: Philco 41-250 Advice Please! - by Mountaineer - 12-07-2017, 09:48 AM
RE: Philco 41-250 Advice Please! - by klondike98 - 12-07-2017, 10:22 AM
RE: Philco 41-250 Advice Please! - by Hot Rod - 12-08-2017, 01:37 PM
The speaker table error?
Philco 70 antenna lead
There are currently 5899 online users. [Complete List]
» 1 Member(s) | 5898 Guest(s)
