Sorta newbie 38-690 low volume
Glad you solved the wire mystery.  I remember that Philco has an adjustment procedure for the MT.  Mine works.  It makes the station come in worse, but at least is does something  Icon_lolno .   I already replaced the 0.7uF and two 0.1uF.
My suspicious 0.1uF cap goes from the center terminal of the treble control then directly to ground, no resistor.  I didn't disconnect it.  I know everything is affected by everything else in the circuit, but didn't think it would in this case.  I will check it disconnected before I condemn it.
I emailed Mark Oppat about a replacement treble control and a new dial but no response as yet.  I hope everything is ok.
I picked up a 1935 Emerson tombstone model 36 last night.  SOMEBODY STOP ME BEFORE I BUY AGAIN!!! Helpsign
Sorta newbie 38-690 low volume - by Hot Rod - 11-29-2017, 09:35 PM
RE: Sorta newbie 38-690 low volume - by morzh - 11-30-2017, 12:22 AM
RE: Sorta newbie 38-690 low volume - by Hot Rod - 11-30-2017, 01:46 PM
RE: Sorta newbie 38-690 low volume - by morzh - 11-30-2017, 02:08 PM
RE: Sorta newbie 38-690 low volume - by Hot Rod - 11-30-2017, 07:45 PM
RE: Sorta newbie 38-690 low volume - by morzh - 12-01-2017, 12:15 AM
RE: Sorta newbie 38-690 low volume - by morzh - 12-01-2017, 12:13 PM
RE: Sorta newbie 38-690 low volume - by Hot Rod - 12-01-2017, 01:08 PM
RE: Sorta newbie 38-690 low volume - by morzh - 12-01-2017, 04:36 PM
RE: Sorta newbie 38-690 low volume - by Hot Rod - 12-03-2017, 05:50 PM
RE: Sorta newbie 38-690 low volume - by morzh - 12-03-2017, 07:20 PM
RE: Sorta newbie 38-690 low volume - by Hot Rod - 12-03-2017, 07:37 PM
RE: Sorta newbie 38-690 low volume - by morzh - 12-03-2017, 11:24 PM
RE: Sorta newbie 38-690 low volume - by morzh - 12-05-2017, 09:33 AM
RE: Sorta newbie 38-690 low volume - by Hot Rod - 12-05-2017, 07:44 PM
RE: Sorta newbie 38-690 low volume - by Hot Rod - 12-05-2017, 07:46 PM
RE: Sorta newbie 38-690 low volume - by Hot Rod - 12-05-2017, 09:28 PM
RE: Sorta newbie 38-690 low volume - by morzh - 12-06-2017, 12:03 AM
RE: Sorta newbie 38-690 low volume - by Hot Rod - 12-06-2017, 01:45 PM
RE: Sorta newbie 38-690 low volume - by morzh - 12-06-2017, 02:26 PM
RE: Sorta newbie 38-690 low volume - by Hot Rod - 12-07-2017, 08:37 PM
RE: Sorta newbie 38-690 low volume - by morzh - 12-07-2017, 08:46 PM
RE: Sorta newbie 38-690 low volume - by Hot Rod - 12-07-2017, 09:47 PM
RE: Sorta newbie 38-690 low volume - by morzh - 12-07-2017, 11:57 PM
RE: Sorta newbie 38-690 low volume - by Hot Rod - 12-08-2017, 01:19 PM
RE: Sorta newbie 38-690 low volume - by morzh - 12-08-2017, 02:39 PM
RE: Sorta newbie 38-690 low volume - by Hot Rod - 12-09-2017, 12:21 AM
RE: Sorta newbie 38-690 low volume - by morzh - 12-09-2017, 11:26 AM
RE: Sorta newbie 38-690 low volume - by Hot Rod - 12-09-2017, 02:39 PM
RE: Sorta newbie 38-690 low volume - by morzh - 12-09-2017, 04:01 PM
RE: Sorta newbie 38-690 low volume - by Hot Rod - 12-09-2017, 08:04 PM
RE: Sorta newbie 38-690 low volume - by morzh - 12-09-2017, 09:37 PM
RE: Sorta newbie 38-690 low volume - by Hot Rod - 12-10-2017, 08:01 PM
RE: Sorta newbie 38-690 low volume - by morzh - 12-10-2017, 08:23 PM
The speaker table error?
Philco 70 antenna lead
