Power up for 24hrs to referbish
I successfully reformed a few caps from end of 40-s or 50-s, axial types in my RF generators and military grade aluminum, painted grey, in two audio generators, BTW these did exceptionally well.
But old radio caps are sometimes simply dry and then no amount of reforming helps as there is no electrolyte, and then lots of crystallization inside also doesn't help.
RE: Power up for 24hrs to referbish - by morzh - 12-04-2017, 07:14 PM
RE: Power up for 24hrs to referbish - by morzh - 12-06-2017, 05:56 PM
RE: Power up for 24hrs to referbish - by Arran - 12-07-2017, 05:26 AM
RE: Power up for 24hrs to referbish - by morzh - 12-07-2017, 08:55 AM
The speaker table error?
Philco 70 antenna lead
