UX201 or UV199 Substitute
If it is possible to run the 6C4 on AC filament voltage it would require all 5 tubes to be replaced. This would probably still result in some hum since the cathode is jumpered to the filament.
I agree on the looks. I would not display a radio with these in it. My intentions were to use them for testing. The fellow that made similar substitutes a few years ago had some test tube glass to cover them with - even silvering some of them to replicate the getter. Maybe somebody could find some at a lab glass vendor. I haven't looked.
The problem with the WD-11 is the base, not just the pins. The pin spacing on a WD-11 is different than the 199, 80, 45 and so on. So you would have to make the whole base for an adaptor.
UX201 or UV199 Substitute - by Phlogiston - 12-04-2017, 04:03 PM
RE: UX201 or 01A Subsistute - by Arran - 12-06-2017, 01:01 AM
RE: UX201 or 01A Subsistute - by Radioroslyn - 12-06-2017, 11:24 AM
RE: UX201 or 01A Subsistute - by Phlogiston - 12-06-2017, 12:05 PM
RE: UX201 or 01A Subsistute - by Ron Ramirez - 12-06-2017, 01:34 PM
RE: UX201 or 01A Subsistute - by Phlogiston - 12-06-2017, 02:18 PM
RE: UX201 or 01A Subsistute - by Arran - 12-07-2017, 01:01 AM
RE: UX201 or 01A Subsistute - by Phlogiston - 12-07-2017, 12:05 PM
RE: UX201 or 01A Substitute - by Arran - 12-08-2017, 12:11 AM
RE: UX201 or 01A Substitute - by Phlogiston - 12-08-2017, 01:01 PM
RE: UX201 or UV199 Substitute - by Arran - 12-10-2017, 02:51 AM
RE: UX201 or UV199 Substitute - by Phlogiston - 12-10-2017, 11:06 AM
RE: UX201 or UV199 Substitute - by Arran - 12-11-2017, 12:49 AM
RE: UX201 or UV199 Substitute - by Phlogiston - 12-11-2017, 11:29 AM
RE: UX201 or UV199 Substitute - by Arran - 12-12-2017, 06:26 AM
RE: UX201 or UV199 Substitute - by Phlogiston - 12-12-2017, 11:55 AM
RE: UX201 or UV199 Substitute - by Arran - 12-13-2017, 03:51 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
