Model 39-55 Holding Relay Sticking Problem
Are you sure that
1. There's no sticky substances?
2. The core is not permanently magnetized (is the relay ac or dc?) ?
3. No weak current for whatever reason keeps flowing through the coil when released?
RE: Model 39-55 Holding Relay Sticking Problem - by morzh - 12-08-2017, 08:47 PM
The speaker table error?
Philco 70 antenna lead
There are currently 5989 online users. [Complete List]
» 1 Member(s) | 5988 Guest(s)
