  • 1 Vote(s) - 3 Average
38-690 Electronic Restoration
Yes this is the article.
The contact I have is bent a bit too much but you get an idea. The handle you press has been removed to not block the view.
38-690 Electronic Restoration - by tbone - 11-08-2017, 08:49 AM
RE: 38-690 Electronic Restoration - by morzh - 11-08-2017, 09:30 AM
RE: 38-690 Electronic Restoration - by tbone - 11-08-2017, 03:32 PM
RE: 38-690 Electronic Restoration - by morzh - 11-08-2017, 03:52 PM
RE: 38-690 Electronic Restoration - by tbone - 12-10-2017, 04:29 PM
RE: 38-690 Electronic Restoration - by tbone - 12-10-2017, 05:31 PM
RE: 38-690 Electronic Restoration - by morzh - 12-10-2017, 06:10 PM
RE: 38-690 Electronic Restoration - by tbone - 12-10-2017, 07:04 PM
RE: 38-690 Electronic Restoration - by morzh - 12-10-2017, 07:33 PM
RE: 38-690 Electronic Restoration - by tbone - 12-10-2017, 09:57 PM
RE: 38-690 Electronic Restoration - by tbone - 12-11-2017, 01:16 PM
RE: 38-690 Electronic Restoration - by morzh - 12-13-2017, 10:59 PM
RE: 38-690 Electronic Restoration - by KCMike - 12-14-2017, 09:36 AM
RE: 38-690 Electronic Restoration - by morzh - 12-14-2017, 10:02 AM
RE: 38-690 Electronic Restoration - by tbone - 12-16-2017, 08:09 AM
RE: 38-690 Electronic Restoration - by tbone - 12-17-2017, 01:41 PM
RE: 38-690 Electronic Restoration - by tbone - 12-20-2017, 08:02 AM
RE: 38-690 Electronic Restoration - by tbone - 12-28-2017, 07:47 PM
RE: 38-690 Electronic Restoration - by morzh - 12-28-2017, 08:06 PM
RE: 38-690 Electronic Restoration - by tbone - 12-28-2017, 08:09 PM
RE: 38-690 Electronic Restoration - by morzh - 12-28-2017, 08:23 PM
RE: 38-690 Electronic Restoration - by tbone - 12-28-2017, 10:15 PM
RE: 38-690 Electronic Restoration - by tbone - 12-29-2017, 10:22 AM
RE: 38-690 Electronic Restoration - by morzh - 12-29-2017, 11:29 AM
RE: 38-690 Electronic Restoration - by tbone - 12-29-2017, 11:35 AM
RE: 38-690 Electronic Restoration - by morzh - 12-29-2017, 12:09 PM
RE: 38-690 Electronic Restoration - by tbone - 12-29-2017, 12:51 PM
RE: 38-690 Electronic Restoration - by tbone - 12-29-2017, 09:48 PM
The speaker table error?
Philco 70 antenna lead
