E.H. Scott model 16 acquired
Here's a picture. The wood brace across the back, allows the chassis to float, and also allows for adjustment as to chassis placement.
E.H. Scott model 16 acquired - by Brad Winder - 12-03-2017, 04:02 PM
RE: E.H. Scott model 16 acquired - by morzh - 12-03-2017, 05:42 PM
RE: E.H. Scott model 16 acquired - by Brad Winder - 12-03-2017, 07:59 PM
RE: E.H. Scott model 16 acquired - by Phlogiston - 12-03-2017, 08:09 PM
RE: E.H. Scott model 16 acquired - by rfeenstra - 12-04-2017, 10:39 AM
RE: E.H. Scott model 16 acquired - by Phlogiston - 12-04-2017, 11:39 AM
RE: E.H. Scott model 16 acquired - by rfeenstra - 12-04-2017, 12:31 PM
RE: E.H. Scott model 16 acquired - by Phlogiston - 12-04-2017, 12:41 PM
RE: E.H. Scott model 16 acquired - by Arran - 12-05-2017, 05:01 AM
RE: E.H. Scott model 16 acquired - by rfeenstra - 12-05-2017, 05:38 PM
RE: E.H. Scott model 16 acquired - by Phlogiston - 12-05-2017, 07:21 PM
RE: E.H. Scott model 16 acquired - by rfeenstra - 12-05-2017, 09:38 PM
RE: E.H. Scott model 16 acquired - by rfeenstra - 12-09-2017, 01:59 PM
RE: E.H. Scott model 16 acquired - by Brad Winder - 12-11-2017, 09:37 PM
RE: E.H. Scott model 16 acquired - by rfeenstra - 12-12-2017, 02:01 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
