RCA 19K vs Crosley 819m Curvflector
Put the little plastic Admiral in your room, it is sure to fit!
RCA 19K vs Crosley 819m Curvflector - by Jayce - 12-11-2017, 10:56 PM
RE: RCA 19K vs Crosley 819m Curvflector - by Paul Philco322 - 12-12-2017, 10:04 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
