Philco 37-10 Console
Hello. I'm a new guy here looking for your expertise. I am wondering if they used any photofinish on the 37-10. I am planning to maybe refinish the console but want to make sure I don't mess it up. My father used to own an electronic repair shop, so no worries on the chassis. He is going to walk me through repairs. Do you think I should refinish this cabinet or leave it alone. He said to just use tung oil, but I have my doubts.Should I just use Restor-A-Finish? Also, there are two spots with veneer bubble. I plan on leaving that alone. I'm afraid if I try to fix it,it will crack. Any advice is greatly appreciated.
Regards,Darrick
Philco 37-10 Console - by Darrick - 04-06-2010, 02:49 PM
Re: Philco 37-10 Console - by Ron Ramirez - 04-06-2010, 03:24 PM
Re: Philco 37-10 Console - by TimC - 04-06-2010, 05:42 PM
Re: Philco 37-10 Console - by Darrick - 04-06-2010, 09:26 PM
Re: Philco 37-10 Console - by TimC - 04-07-2010, 02:40 PM
Re: Philco 37-10 Console - by Darrick - 04-08-2010, 02:50 PM
Re: Philco 37-10 Console - by Bob Andersen - 05-19-2010, 07:18 PM
Re: Philco 37-10 Console - by scottwkurth - 05-20-2010, 10:46 AM
Re: Philco 37-10 Console - by Guest - 09-30-2010, 09:48 PM
There are currently 8770 online users. [Complete List]
» 1 Member(s) | 8769 Guest(s)
