Atwater Kent 55F
A 25Hz radios work fine with 60Hz.
One thing to keep in mind: as the Mains frequency rises, the B+ voltage also does. So the very first capacitor after the rectifier needs to go down in value some to keep the voltage down or the radio will have to work at the increased B+ and this will make tubes run hotter.
Atwater Kent 55F - by rfeenstra - 12-15-2017, 01:10 PM
RE: Atwater Kent 55F - by morzh - 12-15-2017, 02:02 PM
RE: Atwater Kent 55F - by rfeenstra - 12-15-2017, 03:26 PM
RE: Atwater Kent 55F - by Radioroslyn - 12-15-2017, 04:00 PM
RE: Atwater Kent 55F - by rfeenstra - 12-15-2017, 05:01 PM
RE: Atwater Kent 55F - by Arran - 12-16-2017, 05:43 AM
RE: Atwater Kent 55F - by rfeenstra - 12-16-2017, 10:42 AM
RE: Atwater Kent 55F - by Radioroslyn - 12-16-2017, 12:43 PM
RE: Atwater Kent 55F - by tbone - 12-16-2017, 02:44 PM
RE: Atwater Kent 55F - by rfeenstra - 12-17-2017, 01:26 AM
RE: Atwater Kent 55F - by rfeenstra - 12-17-2017, 01:32 AM
RE: Atwater Kent 55F - by Arran - 12-17-2017, 04:10 AM
RE: Atwater Kent 55F - by tbone - 12-17-2017, 07:20 AM
RE: Atwater Kent 55F - by rfeenstra - 12-18-2017, 12:54 AM
RE: Atwater Kent 55F - by rfeenstra - 12-24-2017, 01:14 AM
RE: Atwater Kent 55F - by Radioroslyn - 12-24-2017, 03:39 PM
RE: Atwater Kent 55F - by rfeenstra - 12-25-2017, 11:41 PM
RE: Atwater Kent 55F - by rfeenstra - 12-26-2017, 12:03 PM
RE: Atwater Kent 55F - by Radioroslyn - 12-26-2017, 03:59 PM
RE: Atwater Kent 55F - by rfeenstra - 12-26-2017, 05:45 PM
RE: Atwater Kent 55F - by rfeenstra - 11-09-2020, 09:52 PM
RE: Atwater Kent 55F - by rfeenstra - 11-11-2020, 06:11 PM
RE: Atwater Kent 55F - by klondike98 - 11-12-2020, 12:35 PM
Users browsing this thread: 16 Guest(s)
91H Code 126 Restore
There are currently 5559 online users. [Complete List]
» 1 Member(s) | 5558 Guest(s)
