38-1 code 121A
#39
Well, tomorrow I should be getting final electrical components in the mail. Just tying up loose ends on this unit before final assembly. Something that I've been putting off are the speaker connections... The plug connection from the chassis has only one wire connected to it, and is going to candohm #3320 (this set has 3 separate candohm units), as the other three wires were pulled out of their socket holes at the speaker when I got the radio. I've poured over the schematics, and every time I think I have it, I get an overwhelming feeling of doubt. On the speaker socket, (4 pin connector, 5 wires), with the 2 wide spaced pins on the bottom and the 2 narrow spaced on top, the one wire that is connected from candohm goes to the top left of speaker connection (Narrow section- this has 2 wires at the pin- one to the output transformer, the other to the voice coil). The other wires: one goes to 6f6, another to the next 6f6, and the last goes to #3282 candohm. How shall I attach these wires correctly. Should be a piece of cake, I know, (and I've got a good idea how they should go), but I need verification. THANKS
Jim
38-1 code 121A - by Electrothaumaturgist - 09-28-2017, 01:37 AM
RE: 38-1 code 121A - by Radioroslyn - 09-28-2017, 03:29 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 09-28-2017, 04:01 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 10-28-2017, 03:39 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 10-28-2017, 03:51 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 10-28-2017, 04:13 PM
RE: 38-1 code 121A - by morzh - 10-28-2017, 05:04 PM
RE: 38-1 code 121A - by Radioroslyn - 10-28-2017, 05:12 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 10-28-2017, 06:16 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-08-2017, 01:33 AM
RE: 38-1 code 121A - by Radioroslyn - 11-08-2017, 12:50 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-08-2017, 11:05 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-08-2017, 11:10 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-08-2017, 11:18 PM
RE: 38-1 code 121A - by Radioroslyn - 11-08-2017, 11:25 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-08-2017, 11:35 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-08-2017, 11:38 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-11-2017, 05:33 AM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-18-2017, 03:21 AM
RE: 38-1 code 121A - by Ron Ramirez - 11-18-2017, 09:05 AM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-18-2017, 11:17 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-25-2017, 12:45 AM
RE: 38-1 code 121A - by Radioroslyn - 11-25-2017, 11:42 AM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-25-2017, 04:35 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-28-2017, 03:02 AM
RE: 38-1 code 121A - by Radioroslyn - 11-28-2017, 01:27 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-28-2017, 01:31 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-28-2017, 01:44 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-28-2017, 02:03 PM
RE: 38-1 code 121A - by Radioroslyn - 11-28-2017, 02:47 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-28-2017, 08:33 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-29-2017, 11:13 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 12-03-2017, 07:55 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 12-04-2017, 05:53 PM
RE: 38-1 code 121A - by Radioroslyn - 12-04-2017, 07:38 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 12-04-2017, 08:35 PM
RE: 38-1 code 121A - by Radioroslyn - 12-04-2017, 08:52 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 12-04-2017, 10:13 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 12-16-2017, 01:20 AM
RE: 38-1 code 121A - by Electrothaumaturgist - 12-16-2017, 06:48 AM
RE: 38-1 code 121A - by Electrothaumaturgist - 12-25-2017, 04:42 PM
RE: 38-1 code 121A - by EdHolland - 12-26-2017, 10:45 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 12-27-2017, 07:16 PM
The speaker table error?
Philco 70 antenna lead
