Adding A supply to this B Battery Eliminator
Thank you!! Sorry for the confusion....I thought at first that LM317T was a choke and I know some of those run $30 or more. We both must've been typing at the same time....saw you edited your first post and it answered that question.
Found this on AES, will that work?
https://www.tubesandmore.com/products/tr...-regulator
Should I use 2 of each diode in parallel or just for the IN4004?
RE: Adding A supply to this B Battery Eliminator - by NostalgiaRadioTime - 12-17-2017, 02:41 AM
The speaker table error?
Philco 70 antenna lead
