Philco 38-690 electronics restoration.
Threads: 18
City: Cromwell
State, Province, Country: CT
OK, if you look at the picture of the chassis in my photo album, you will see that the gum rubber bumpers you have go into the block of wood and push the chassis up forward into the cabinet more. This should give you enough of the shafts poking out to install the knobs. The 1/4" carriage bolt holds most of the weight, but there are two small holes in the block for wood screws. They will keep the block from turning once it's in the final position.
https://www.flickr.com/photos/152428891@...ed-public/
RE: Philco 38-690 electronics restoration. - by tbone - 12-17-2017, 01:32 PM
Users browsing this thread: 36 Guest(s)
The speaker table error?
G 10-1/2" 65, 76, 87, 95
Push-Pull 45's
2766
0.7
550
3200
H 10-1/2" 77, 96
Push-Pull...morzh — 09:26 PM |
I have a Stromberg, one of the early ones, seems early 30s.
This is what I call a back breaker. None of the early Philc...morzh — 08:28 PM |
A backbreaker.....PaulPaul Philco322 — 08:12 PM |
>>What a behemoth!
A Juggernaut.morzh — 07:47 PM |
Philco 70 antenna lead
I am not sure I understood about the coils and the mush. I looked an more than one coil in 20, 70, 90, 60, Zeniths and ...morzh — 07:46 PM |
:e_biggrin: What a behemoth! I hope the final result is as much a quality sounding example! Keep us posted on your pro...GarySP — 07:32 PM |
I should add that the double conversion may only be used on the shortwave bands, but I haven't looked at the schematic t...Arran — 07:27 PM |
Yes, that wire will not pick up much interference as routed - the RF at that level won't be affected, and if you have st...radio1 — 07:26 PM |
I'm also a member of MARC. Did you attend the Vintage Electronics Expo in Waterford, MI last month? That's where I got...GarySP — 07:22 PM |
Dan
Double conversion is using two IF converters instead of one. This improves the image response.
morzh — 07:15 PM |
