Adding A supply to this B Battery Eliminator
Back on April 1 2016 I posted a picture of a power supply I was using on a M Wards farm radio. Sorry but I do not know how to repost that info from the old post. Contained a isolation transformer and a A,B,C power supply. Simple to make. David
RE: Adding A supply to this B Battery Eliminator - by David - 12-17-2017, 08:53 PM
The speaker table error?
Philco 70 antenna lead
There are currently 3272 online users. [Complete List]
» 1 Member(s) | 3271 Guest(s)
