1934 crosley 6H2 problem
Hi Murf and Merry Christmas  https://www.youtube.com/watch?v=Ooc5eJc5SHA
Bit odd. I would inject a 456kc modulated signal at the cap of the 6A7 and peak up the two IF transformers. Methinks someone has been dittling w/them.
1934 crosley 6H2 problem - by murf - 12-18-2017, 05:15 PM
RE: 1934 crosley 6H2 problem - by Radioroslyn - 12-18-2017, 06:54 PM
RE: 1934 crosley 6H2 problem - by murf - 12-18-2017, 10:01 PM
RE: 1934 crosley 6H2 problem - by murf - 12-18-2017, 10:18 PM
RE: 1934 crosley 6H2 problem - by morzh - 12-18-2017, 10:22 PM
RE: 1934 crosley 6H2 problem - by Radioroslyn - 12-18-2017, 10:30 PM
RE: 1934 crosley 6H2 problem - by murf - 12-18-2017, 10:48 PM
RE: 1934 crosley 6H2 problem - by Arran - 12-21-2017, 01:45 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 3559 online users. [Complete List]
» 1 Member(s) | 3558 Guest(s)
