PT-25 audio distortion
I use De-ox-id contact cleaner, part # 19-1906-A
There are 7 resistors. A few are pin to pin that seem to require their removal to test so I might as well install a new one.
I haven't changed the speaker. It played when I bought the set and with each replaced cap the audio quality has improved. It's just not at where I know it should be even for a small table top set.
Very much appreciate the help guys. Trying to finish this set up for a Xmas gift for my dad, and move on to a 16B that I've very stoked about starting.
PT-25 audio distortion - by WyTex - 12-19-2017, 12:45 PM
RE: PT-25 audio distortion - by morzh - 12-19-2017, 02:29 PM
RE: PT-25 audio distortion - by David - 12-19-2017, 04:08 PM
RE: PT-25 audio distortion - by WyTex - 12-19-2017, 04:09 PM
RE: PT-25 audio distortion - by Phlogiston - 12-19-2017, 04:37 PM
RE: PT-25 audio distortion - by morzh - 12-19-2017, 11:02 PM
RE: PT-25 audio distortion - by WyTex - 12-20-2017, 10:06 AM
RE: PT-25 audio distortion - by Steve Davis - 12-20-2017, 11:34 AM
RE: PT-25 audio distortion - by Phlogiston - 12-20-2017, 11:52 AM
RE: PT-25 audio distortion - by klondike98 - 12-20-2017, 12:01 PM
RE: PT-25 audio distortion - by Phlogiston - 12-20-2017, 03:28 PM
RE: PT-25 audio distortion - by klondike98 - 12-20-2017, 05:45 PM
RE: PT-25 audio distortion - by WyTex - 12-20-2017, 06:16 PM
RE: PT-25 audio distortion - by morzh - 12-20-2017, 06:46 PM
RE: PT-25 audio distortion - by klondike98 - 12-20-2017, 06:48 PM
RE: PT-25 audio distortion - by Arran - 12-21-2017, 01:52 AM
RE: PT-25 audio distortion - by morzh - 12-21-2017, 10:32 AM
RE: PT-25 audio distortion - by WyTex - 12-21-2017, 10:58 AM
RE: PT-25 audio distortion - by Phlogiston - 12-21-2017, 12:05 PM
RE: PT-25 audio distortion - by Radioroslyn - 12-21-2017, 12:33 PM
RE: PT-25 audio distortion - by morzh - 12-21-2017, 01:14 PM
RE: PT-25 audio distortion - by WyTex - 01-05-2018, 02:26 PM
RE: PT-25 audio distortion - by morzh - 01-05-2018, 06:09 PM
The speaker table error?
Philco 70 antenna lead
There are currently 5885 online users. [Complete List]
» 1 Member(s) | 5884 Guest(s)
