PT-25 audio distortion
(12-20-2017, 03:28 PM)Phlogiston Wrote:  I've never seen De-ox-id (if I were Caig, I'd look for a lawyer)
That's what I was thinking Russ!
PT-25 audio distortion - by WyTex - 12-19-2017, 12:45 PM
RE: PT-25 audio distortion - by morzh - 12-19-2017, 02:29 PM
RE: PT-25 audio distortion - by David - 12-19-2017, 04:08 PM
RE: PT-25 audio distortion - by WyTex - 12-19-2017, 04:09 PM
RE: PT-25 audio distortion - by Phlogiston - 12-19-2017, 04:37 PM
RE: PT-25 audio distortion - by morzh - 12-19-2017, 11:02 PM
RE: PT-25 audio distortion - by WyTex - 12-20-2017, 10:06 AM
RE: PT-25 audio distortion - by Steve Davis - 12-20-2017, 11:34 AM
RE: PT-25 audio distortion - by Phlogiston - 12-20-2017, 11:52 AM
RE: PT-25 audio distortion - by klondike98 - 12-20-2017, 12:01 PM
RE: PT-25 audio distortion - by Phlogiston - 12-20-2017, 03:28 PM
RE: PT-25 audio distortion - by klondike98 - 12-20-2017, 05:45 PM
RE: PT-25 audio distortion - by WyTex - 12-20-2017, 06:16 PM
RE: PT-25 audio distortion - by morzh - 12-20-2017, 06:46 PM
RE: PT-25 audio distortion - by klondike98 - 12-20-2017, 06:48 PM
RE: PT-25 audio distortion - by Arran - 12-21-2017, 01:52 AM
RE: PT-25 audio distortion - by morzh - 12-21-2017, 10:32 AM
RE: PT-25 audio distortion - by WyTex - 12-21-2017, 10:58 AM
RE: PT-25 audio distortion - by Phlogiston - 12-21-2017, 12:05 PM
RE: PT-25 audio distortion - by Radioroslyn - 12-21-2017, 12:33 PM
RE: PT-25 audio distortion - by morzh - 12-21-2017, 01:14 PM
RE: PT-25 audio distortion - by WyTex - 01-05-2018, 02:26 PM
RE: PT-25 audio distortion - by morzh - 01-05-2018, 06:09 PM
The speaker table error?
Philco 70 antenna lead
