PT-25 audio distortion
If you suspect the pot, then find a station that is received well enough to be heard well but not too loud at say half pot scale, disconect the pot, and connect two resistors, one between the low point and wiper being, say 50K and the othe between the wiper and the top point being 450K (values are approximate, don't have to be exact) and see if the distortion persists.
I doubt it, but possible.
PT-25 audio distortion - by WyTex - 12-19-2017, 12:45 PM
RE: PT-25 audio distortion - by morzh - 12-19-2017, 02:29 PM
RE: PT-25 audio distortion - by David - 12-19-2017, 04:08 PM
RE: PT-25 audio distortion - by WyTex - 12-19-2017, 04:09 PM
RE: PT-25 audio distortion - by Phlogiston - 12-19-2017, 04:37 PM
RE: PT-25 audio distortion - by morzh - 12-19-2017, 11:02 PM
RE: PT-25 audio distortion - by WyTex - 12-20-2017, 10:06 AM
RE: PT-25 audio distortion - by Steve Davis - 12-20-2017, 11:34 AM
RE: PT-25 audio distortion - by Phlogiston - 12-20-2017, 11:52 AM
RE: PT-25 audio distortion - by klondike98 - 12-20-2017, 12:01 PM
RE: PT-25 audio distortion - by Phlogiston - 12-20-2017, 03:28 PM
RE: PT-25 audio distortion - by klondike98 - 12-20-2017, 05:45 PM
RE: PT-25 audio distortion - by WyTex - 12-20-2017, 06:16 PM
RE: PT-25 audio distortion - by morzh - 12-20-2017, 06:46 PM
RE: PT-25 audio distortion - by klondike98 - 12-20-2017, 06:48 PM
RE: PT-25 audio distortion - by Arran - 12-21-2017, 01:52 AM
RE: PT-25 audio distortion - by morzh - 12-21-2017, 10:32 AM
RE: PT-25 audio distortion - by WyTex - 12-21-2017, 10:58 AM
RE: PT-25 audio distortion - by Phlogiston - 12-21-2017, 12:05 PM
RE: PT-25 audio distortion - by Radioroslyn - 12-21-2017, 12:33 PM
RE: PT-25 audio distortion - by morzh - 12-21-2017, 01:14 PM
RE: PT-25 audio distortion - by WyTex - 01-05-2018, 02:26 PM
RE: PT-25 audio distortion - by morzh - 01-05-2018, 06:09 PM
The speaker table error?
Philco 70 antenna lead
There are currently 6134 online users. [Complete List]
» 1 Member(s) | 6133 Guest(s)
