Philco Model 20 rebuild - thanks for all the info
Same is my 90 that I did the same mod to. It is not a daily player. I have 37-116 for that and now 38-690.
This said, 20 with the original speaker as a player of any music isn't the best chouce unless for now you have no alternative. Even when the speaker is reconed and the spider is changed. Though in this case it should be a decent player for sources like iPod if the connectors are installed.
RE: Philco Model 20 rebuild - thanks for all the info - by morzh - 12-21-2017, 05:06 PM
The speaker table error?
Philco 70 antenna lead
