Philco Model 256F UK Model ?
Thanks so much Ron this is a real help! Now I have the service data will be able to sort this radio out.
As I have said I will start a new thread on the restoration of the set.
Couldn't have got this far without you Guys. Ordered myself a 39/44 valve and a spare 36 before I get started on it.
Dave
Philco Model 256F UK Model ? - by Radiomad1 - 11-29-2017, 10:42 AM
RE: Philco Model 256F UK Model ? - by morzh - 11-29-2017, 12:13 PM
RE: Philco Model 256F UK Model ? - by Radiomad1 - 11-29-2017, 12:50 PM
RE: Philco Model 256F UK Model ? - by Radiomad1 - 11-29-2017, 01:06 PM
RE: Philco Model 256F UK Model ? - by Radioroslyn - 11-29-2017, 01:08 PM
RE: Philco Model 256F UK Model ? - by Ron Ramirez - 11-29-2017, 07:29 PM
RE: Philco Model 256F UK Model ? - by Radiomad1 - 11-30-2017, 06:45 AM
RE: Philco Model 256F UK Model ? - by Ron Ramirez - 12-01-2017, 07:21 PM
RE: Philco Model 256F UK Model ? - by Radiomad1 - 12-21-2017, 09:08 AM
RE: Philco Model 256F UK Model ? - by Radiomad1 - 12-21-2017, 10:08 AM
RE: Philco Model 256F UK Model ? - by klondike98 - 12-21-2017, 10:13 AM
RE: Philco Model 256F UK Model ? - by Radiomad1 - 12-21-2017, 12:25 PM
RE: Philco Model 256F UK Model ? - by morzh - 12-21-2017, 01:51 PM
RE: Philco Model 256F UK Model ? - by Ron Ramirez - 12-21-2017, 08:11 PM
RE: Philco Model 256F UK Model ? - by Radiomad1 - 12-22-2017, 05:08 AM
RE: Philco Model 256F UK Model ? - by Arran - 12-26-2017, 04:44 AM
Philco 91 Restore Code ??
Philco 40-120C Restoration
RCA T62 is playing.....
Philco 89 indicator light.
Thank you Rod.  Hello MrFixr55. Thank you for the long reply. My radio is the 121 version (1 speaker) and I am aware ...dconant — 06:36 PM
Your 8 watt transformer is good, the 42s produce 6 watts and you won't be sending maximum volume to the speaker anyway. ...RodB — 05:54 PM
There are currently 3201 online users. [Complete List]
» 1 Member(s) | 3200 Guest(s)
