Philco 66 Faceplate
Hello. You might look at the 2 dials Radio daze has on their site. One dial shows it works for both 60 & 66 the other is a 66/ 66S/66X Don't know for sure which one you would need.
Here's the link.
http://www.radiodaze.com/dials-plastic-o...red&page=4
Philco 66 Faceplate - by dacsman - 12-21-2017, 10:21 AM
RE: Philco 66 Faceplate - by KCMike - 12-22-2017, 03:45 PM
RE: Philco 66 Faceplate - by Ron Ramirez - 12-22-2017, 04:26 PM
RE: Philco 66 Faceplate - by Radioroslyn - 12-22-2017, 05:01 PM
RE: Philco 66 Faceplate - by Ron Ramirez - 12-22-2017, 05:07 PM
RE: Philco 66 Faceplate - by dacsman - 12-22-2017, 06:55 PM
There are currently 5241 online users. [Complete List]
» 2 Member(s) | 5239 Guest(s)
