Correct grill cloth for 16B cathedral
Another question regarding the 16B cathedral:
What was the original veneer species used on the case, Walnut or African Mahogany?
Thx
Re: Correct grill cloth for 16B cathedral - by frankpe - 04-09-2010, 08:21 PM
There are currently 4983 online users. [Complete List]
» 1 Member(s) | 4982 Guest(s)
