37-650 Issues
Scott:
Where are you measuring these AC voltages? Shouldn't be AC on anything except the heater pins and the rectifier. Maybe your meter is set wrong? If you measure overly high DC voltage on the screens and plates then tubes aren't drawing current. I would suspect a wiring error since you said you replaced all of it. You're going to have to trace it all out very carefully, I think. Icon_sad Hang in there, it's a great radio, have one on my "bench" now.
Steve Chambers
37-650 Issues - by Robbie Roberts - 01-27-2006, 07:06 AM
[No subject] - by Steve Chambers - 01-27-2006, 08:01 AM
[No subject] - by Robbie Roberts - 01-27-2006, 12:07 PM
[No subject] - by Steve Chambers - 01-27-2006, 12:21 PM
[No subject] - by Robbie Roberts - 01-27-2006, 12:32 PM
[No subject] - by Robbie Roberts - 01-27-2006, 06:02 PM
[No subject] - by Steve Chambers - 01-27-2006, 06:23 PM
[No subject] - by Robbie Roberts - 01-27-2006, 06:29 PM
[No subject] - by Steve Chambers - 01-27-2006, 06:38 PM
[No subject] - by Robbie Roberts - 01-27-2006, 06:41 PM
[No subject] - by Robbie Roberts - 01-27-2006, 06:51 PM
[No subject] - by Steve Chambers - 01-27-2006, 07:05 PM
[No subject] - by Robbie Roberts - 01-27-2006, 07:44 PM
[No subject] - by Robbie Roberts - 01-27-2006, 09:07 PM
[No subject] - by Robbie Roberts - 01-30-2006, 05:12 PM
[No subject] - by Chuck Schwark - 01-30-2006, 07:53 PM
[No subject] - by Steve Chambers - 01-30-2006, 07:59 PM
[No subject] - by Robbie Roberts - 01-30-2006, 08:02 PM
[No subject] - by Chuck Schwark - 01-30-2006, 08:12 PM
[No subject] - by Robbie Roberts - 01-31-2006, 12:52 AM
[No subject] - by Chuck Schwark - 01-31-2006, 09:57 AM
[No subject] - by Robbie Roberts - 01-31-2006, 11:43 AM
[No subject] - by Robbie Roberts - 01-31-2006, 06:40 PM
[No subject] - by Steve Chambers - 01-31-2006, 08:53 PM
[No subject] - by Robbie Roberts - 02-02-2006, 09:24 AM
[No subject] - by Steve Chambers - 02-02-2006, 05:00 PM
[No subject] - by Chuck Schwark - 02-02-2006, 05:47 PM
[No subject] - by Robbie Roberts - 02-02-2006, 06:24 PM
[No subject] - by Chuck Schwark - 02-02-2006, 07:42 PM
[No subject] - by Robbie Roberts - 02-02-2006, 07:43 PM
[No subject] - by Robbie Roberts - 02-02-2006, 08:36 PM
[No subject] - by Chuck Schwark - 02-02-2006, 10:22 PM
[No subject] - by Robbie Roberts - 02-02-2006, 11:03 PM
[No subject] - by Bill Hutchinson - 02-03-2006, 03:20 PM
[No subject] - by Robbie Roberts - 02-03-2006, 03:26 PM
[No subject] - by Bill Hutchinson - 02-03-2006, 07:08 PM
[No subject] - by Robbie Roberts - 02-04-2006, 08:29 AM
[No subject] - by Robbie Roberts - 02-05-2006, 01:42 AM
[No subject] - by 49Stude63 - 02-05-2006, 11:07 AM
Philco 91 Tuning Condenser
There are currently 9950 online users. [Complete List]
» 1 Member(s) | 9949 Guest(s)
