Signal Injection Question
Well. I'd start looking in places I touched, checking aps values, wiring etc, now that we know that the tubes are likely ok since it played before.
On using the scope: DO NOT usethe scope on this radio unless you have an isolation transformer and can plug the radio through it. Or unless it is a battery-powered scope.
Signal Injection Question - by Welder - 12-24-2017, 06:02 AM
RE: Signal Injection Question - by Phlogiston - 12-24-2017, 11:13 AM
RE: Signal Injection Question - by Welder - 12-24-2017, 11:51 AM
RE: Signal Injection Question - by Phlogiston - 12-24-2017, 12:00 PM
RE: Signal Injection Question - by morzh - 12-24-2017, 12:07 PM
RE: Signal Injection Question - by Radioroslyn - 12-24-2017, 12:41 PM
RE: Signal Injection Question - by Welder - 12-24-2017, 03:17 PM
RE: Signal Injection Question - by morzh - 12-24-2017, 04:41 PM
RE: Signal Injection Question - by Welder - 12-24-2017, 06:20 PM
RE: Signal Injection Question - by David - 12-24-2017, 10:01 PM
RE: Signal Injection Question - by David - 12-24-2017, 10:12 PM
RE: Signal Injection Question - by morzh - 12-24-2017, 11:45 PM
RE: Signal Injection Question - by Welder - 12-25-2017, 05:49 AM
RE: Signal Injection Question - by Welder - 12-25-2017, 05:54 AM
RE: Signal Injection Question - by morzh - 12-25-2017, 07:41 PM
RE: Signal Injection Question - by Welder - 12-25-2017, 10:25 PM
RE: Signal Injection Question - by morzh - 12-25-2017, 10:37 PM
RE: Signal Injection Question - by Welder - 12-26-2017, 07:12 AM
RE: Signal Injection Question - by morzh - 12-26-2017, 11:59 AM
RE: Signal Injection Question - by Welder - 12-26-2017, 09:50 PM
RE: Signal Injection Question - by morzh - 12-26-2017, 10:33 PM
RE: Signal Injection Question - by Radioroslyn - 12-27-2017, 01:08 AM
RE: Signal Injection Question - by Welder - 12-27-2017, 07:10 AM
RE: Signal Injection Question - by morzh - 12-27-2017, 10:23 AM
RE: Signal Injection Question - by Welder - 12-27-2017, 01:37 PM
RE: Signal Injection Question - by oldswab37 - 12-27-2017, 04:37 PM
RE: Signal Injection Question - by Welder - 12-27-2017, 06:04 PM
RE: Signal Injection Question - by morzh - 12-27-2017, 06:09 PM
RE: Signal Injection Question - by Welder - 12-27-2017, 07:47 PM
RE: Signal Injection Question - by morzh - 12-28-2017, 01:02 AM
RE: Signal Injection Question - by Welder - 12-28-2017, 05:19 AM
RE: Signal Injection Question - by morzh - 12-28-2017, 12:56 PM
RE: Signal Injection Question - by morzh - 01-03-2018, 10:10 PM
RE: Signal Injection Question - by Welder - 01-04-2018, 05:51 AM
RE: Signal Injection Question - by morzh - 01-04-2018, 02:50 PM
RE: Signal Injection Question - by Welder - 01-04-2018, 06:41 PM
RE: Signal Injection Question - by morzh - 01-04-2018, 06:52 PM
RE: Signal Injection Question - by Welder - 01-08-2018, 05:41 PM
RE: Signal Injection Question - by morzh - 01-08-2018, 05:48 PM
RE: Signal Injection Question - by Welder - 01-08-2018, 07:05 PM
RE: Signal Injection Question - by jcassity - 01-17-2018, 10:07 AM
RE: Signal Injection Question - by morzh - 01-17-2018, 10:53 AM
RE: Signal Injection Question - by jcassity - 01-17-2018, 11:13 AM
RE: Signal Injection Question - by morzh - 01-17-2018, 02:50 PM
Users browsing this thread: 16 Guest(s)
The speaker table error?
Philco 70 antenna lead
There are currently 6665 online users. [Complete List]
» 2 Member(s) | 6663 Guest(s)
