Philco 42-380 120 Hz Hum
Do you have any switching converters / ccgl lamps etc at home?
Often times the hum is a result of them working. You could try switching things one by one to see if it disappears.
Also if you have a transistor radio, set itnearby and see if you have the same hum.
Philco 42-380 120 Hz Hum - by Jason63 - 12-27-2017, 05:31 PM
RE: Philco 42-380 120 Hz Hum - by morzh - 12-27-2017, 06:07 PM
RE: Philco 42-380 120 Hz Hum - by Jason63 - 12-27-2017, 08:38 PM
RE: Philco 42-380 120 Hz Hum - by Radioroslyn - 12-27-2017, 09:03 PM
RE: Philco 42-380 120 Hz Hum - by klondike98 - 12-27-2017, 10:12 PM
RE: Philco 42-380 120 Hz Hum - by Jason63 - 12-28-2017, 11:01 AM
RE: Philco 42-380 120 Hz Hum - by morzh - 12-28-2017, 12:47 PM
RE: Philco 42-380 120 Hz Hum - by Jason63 - 12-28-2017, 03:08 PM
RE: Philco 42-380 120 Hz Hum - by morzh - 12-28-2017, 03:31 PM
RE: Philco 42-380 120 Hz Hum - by Radioroslyn - 12-28-2017, 03:34 PM
RE: Philco 42-380 120 Hz Hum - by Jason63 - 12-29-2017, 06:55 PM
The speaker table error?
Philco 70 antenna lead
