42-380 Restoration Started
Rectifier and audio output tubes normally run hot, while other tubes in a set generally do not. So, yes, the temperatures can (and do) indeed vary that much.
42-380 Restoration Started - by rkeller - 03-28-2010, 06:38 PM
Re: 42-380 Restoration Started - by dberman51 - 03-28-2010, 08:09 PM
Re: 42-380 Restoration Started - by DeckApe - 03-30-2010, 09:27 AM
Re: 42-380 Restoration Started - by rkeller - 04-10-2010, 07:46 AM
Re: 42-380 Restoration Started - by codefox1 - 04-10-2010, 10:39 AM
Re: 42-380 Restoration Started - by rkeller - 04-14-2010, 07:40 PM
Re: 42-380 Restoration Started - by Ron Ramirez - 04-14-2010, 08:50 PM
Re: 42-380 Restoration Started - by rkeller - 04-17-2010, 12:36 PM
Re: 42-380 Restoration Started - by DeckApe - 04-20-2010, 05:04 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
