Signal Injection Question
#34
6A8 tube is at the back of the chassis (close to you and away from the front panel) between the tu ing cap and the 1sr IF can.
The T3 oscillator transformer and C9 cap are at the bottom of the chassis, mounted at the side by the tuning shaft.
Signal Injection Question - by Welder - 12-24-2017, 06:02 AM
RE: Signal Injection Question - by Phlogiston - 12-24-2017, 11:13 AM
RE: Signal Injection Question - by Welder - 12-24-2017, 11:51 AM
RE: Signal Injection Question - by Phlogiston - 12-24-2017, 12:00 PM
RE: Signal Injection Question - by morzh - 12-24-2017, 12:07 PM
RE: Signal Injection Question - by Radioroslyn - 12-24-2017, 12:41 PM
RE: Signal Injection Question - by Welder - 12-24-2017, 03:17 PM
RE: Signal Injection Question - by morzh - 12-24-2017, 04:41 PM
RE: Signal Injection Question - by Welder - 12-24-2017, 06:20 PM
RE: Signal Injection Question - by David - 12-24-2017, 10:01 PM
RE: Signal Injection Question - by David - 12-24-2017, 10:12 PM
RE: Signal Injection Question - by morzh - 12-24-2017, 11:45 PM
RE: Signal Injection Question - by Welder - 12-25-2017, 05:49 AM
RE: Signal Injection Question - by Welder - 12-25-2017, 05:54 AM
RE: Signal Injection Question - by morzh - 12-25-2017, 07:41 PM
RE: Signal Injection Question - by Welder - 12-25-2017, 10:25 PM
RE: Signal Injection Question - by morzh - 12-25-2017, 10:37 PM
RE: Signal Injection Question - by Welder - 12-26-2017, 07:12 AM
RE: Signal Injection Question - by morzh - 12-26-2017, 11:59 AM
RE: Signal Injection Question - by Welder - 12-26-2017, 09:50 PM
RE: Signal Injection Question - by morzh - 12-26-2017, 10:33 PM
RE: Signal Injection Question - by Radioroslyn - 12-27-2017, 01:08 AM
RE: Signal Injection Question - by Welder - 12-27-2017, 07:10 AM
RE: Signal Injection Question - by morzh - 12-27-2017, 10:23 AM
RE: Signal Injection Question - by Welder - 12-27-2017, 01:37 PM
RE: Signal Injection Question - by oldswab37 - 12-27-2017, 04:37 PM
RE: Signal Injection Question - by Welder - 12-27-2017, 06:04 PM
RE: Signal Injection Question - by morzh - 12-27-2017, 06:09 PM
RE: Signal Injection Question - by Welder - 12-27-2017, 07:47 PM
RE: Signal Injection Question - by morzh - 12-28-2017, 01:02 AM
RE: Signal Injection Question - by Welder - 12-28-2017, 05:19 AM
RE: Signal Injection Question - by morzh - 12-28-2017, 12:56 PM
RE: Signal Injection Question - by morzh - 01-03-2018, 10:10 PM
RE: Signal Injection Question - by Welder - 01-04-2018, 05:51 AM
RE: Signal Injection Question - by morzh - 01-04-2018, 02:50 PM
RE: Signal Injection Question - by Welder - 01-04-2018, 06:41 PM
RE: Signal Injection Question - by morzh - 01-04-2018, 06:52 PM
RE: Signal Injection Question - by Welder - 01-08-2018, 05:41 PM
RE: Signal Injection Question - by morzh - 01-08-2018, 05:48 PM
RE: Signal Injection Question - by Welder - 01-08-2018, 07:05 PM
RE: Signal Injection Question - by jcassity - 01-17-2018, 10:07 AM
RE: Signal Injection Question - by morzh - 01-17-2018, 10:53 AM
RE: Signal Injection Question - by jcassity - 01-17-2018, 11:13 AM
RE: Signal Injection Question - by morzh - 01-17-2018, 02:50 PM
The speaker table error?
Philco 70 antenna lead
There are currently 5936 online users. [Complete List]
» 1 Member(s) | 5935 Guest(s)
