Adding A supply to this B Battery Eliminator
#32
I should also mention the speaker in the radio is a smaller diameter replacement 4 ohm permanent magnet speaker I had on hand. The original was blown... the cone was bowed outward and it had no volume. Because the replacement speaker is not quite as tall as the original, the box fit nicely in front of it in the cabinet. With the original speaker you may have to leave the cover off of the power supply box to get it to fit in the cabinet (if you use the power supply in a 39-70 cabinet). Of course, if you leave the box outside the cabinet, it's not an issue... plus you'd have the option of using it for other battery powered radios as well.
RE: Adding A supply to this B Battery Eliminator - by NostalgiaRadioTime - 12-29-2017, 12:20 AM
The speaker table error?
Philco 70 antenna lead
There are currently 5925 online users. [Complete List]
» 1 Member(s) | 5924 Guest(s)
