  • 1 Vote(s) - 3 Average
38-690 Electronic Restoration
Did you see if your dial's notch is over the ridge on the hub over which it goes? Does the dial have any play?
I think it is those single lines that separate the text from the scale that are supposed to line up with the light line.
And that stop cannot really be adjusted.
38-690 Electronic Restoration - by tbone - 11-08-2017, 08:49 AM
RE: 38-690 Electronic Restoration - by morzh - 11-08-2017, 09:30 AM
RE: 38-690 Electronic Restoration - by tbone - 11-08-2017, 03:32 PM
RE: 38-690 Electronic Restoration - by morzh - 11-08-2017, 03:52 PM
RE: 38-690 Electronic Restoration - by tbone - 12-10-2017, 04:29 PM
RE: 38-690 Electronic Restoration - by tbone - 12-10-2017, 05:31 PM
RE: 38-690 Electronic Restoration - by morzh - 12-10-2017, 06:10 PM
RE: 38-690 Electronic Restoration - by tbone - 12-10-2017, 07:04 PM
RE: 38-690 Electronic Restoration - by morzh - 12-10-2017, 07:33 PM
RE: 38-690 Electronic Restoration - by tbone - 12-10-2017, 09:57 PM
RE: 38-690 Electronic Restoration - by tbone - 12-11-2017, 01:16 PM
RE: 38-690 Electronic Restoration - by morzh - 12-13-2017, 10:59 PM
RE: 38-690 Electronic Restoration - by KCMike - 12-14-2017, 09:36 AM
RE: 38-690 Electronic Restoration - by morzh - 12-14-2017, 10:02 AM
RE: 38-690 Electronic Restoration - by tbone - 12-16-2017, 08:09 AM
RE: 38-690 Electronic Restoration - by tbone - 12-17-2017, 01:41 PM
RE: 38-690 Electronic Restoration - by tbone - 12-20-2017, 08:02 AM
RE: 38-690 Electronic Restoration - by tbone - 12-28-2017, 07:47 PM
RE: 38-690 Electronic Restoration - by morzh - 12-28-2017, 08:06 PM
RE: 38-690 Electronic Restoration - by tbone - 12-28-2017, 08:09 PM
RE: 38-690 Electronic Restoration - by morzh - 12-28-2017, 08:23 PM
RE: 38-690 Electronic Restoration - by tbone - 12-28-2017, 10:15 PM
RE: 38-690 Electronic Restoration - by tbone - 12-29-2017, 10:22 AM
RE: 38-690 Electronic Restoration - by morzh - 12-29-2017, 11:29 AM
RE: 38-690 Electronic Restoration - by tbone - 12-29-2017, 11:35 AM
RE: 38-690 Electronic Restoration - by morzh - 12-29-2017, 12:09 PM
RE: 38-690 Electronic Restoration - by tbone - 12-29-2017, 12:51 PM
RE: 38-690 Electronic Restoration - by tbone - 12-29-2017, 09:48 PM
The speaker table error?
Philco 70 antenna lead
There are currently 6764 online users. [Complete List]
» 2 Member(s) | 6762 Guest(s)
