40-185 Restoration Project - The Cabinet
For easy nick hiding they sell magic markers in various wood colors. The one I have is by Mohawk, their p/n M267-0209. Shouldn't be hard to find one or a similar product.
If it were me I'd use a good coat of paste wax as a followup to the Howard's. I wouldn't want to try to refresh anything on that nice a cabinet with a spray can of lacquer.
As for that blemish on the bottom. It looks like a bad ding in the photo but fortunately its in a location that really doesn't detract from the radio. I think you'll get used to it Icon_smile
Re: 40-185 Restoration Project - The Cabinet - by exray - 04-17-2010, 08:01 AM
There are currently 10508 online users. [Complete List]
» 2 Member(s) | 10506 Guest(s)
