Philco hippo/ Canadian
Kinda odd tube lineup. Would think it should have a 7C6 near the 50L6 not a 2nd 7B7. Does it have sticker inside to check tube arrangement??
Philco hippo/ Canadian - by Digdug - 12-30-2017, 03:58 PM
RE: Philco hippo/ Canadian - by klondike98 - 12-30-2017, 04:37 PM
RE: Philco hippo/ Canadian - by Digdug - 12-30-2017, 05:27 PM
RE: Philco hippo/ Canadian - by Radioroslyn - 12-31-2017, 12:22 AM
RE: Philco hippo/ Canadian - by Digdug - 12-31-2017, 01:49 PM
The speaker table error?
Philco 70 antenna lead
