Philco 37-660 chassis question
I am looking for parts for this chassis and was wondering which other models used the same design as the 37-660.
I am trying to locate a replacement for the band select lever.
Bill
Philco 37-660 chassis question - by Bill njb - 05-18-2010, 11:06 PM
Re: Philco 37-660 chassis question - by BDM - 06-01-2010, 01:00 PM
Re: Philco 37-660 chassis question - by Bill njb - 06-02-2010, 09:19 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6855 online users. [Complete List]
» 1 Member(s) | 6854 Guest(s)
