Philco 41-290
Hi and welcome,
I did one on a 41-300 several months ago.
http://philcoradio.com/phorum/showthread.php?tid=17076
Philco 41-290 - by verb - 01-02-2018, 08:11 PM
RE: Philco 41-290 - by KCMike - 01-02-2018, 08:58 PM
RE: Philco 41-290 - by klondike98 - 01-02-2018, 09:17 PM
RE: Philco 41-290 - by Radioroslyn - 01-02-2018, 11:08 PM
RE: Philco 41-290 - by verb - 01-02-2018, 11:54 PM
RE: Philco 41-290 - by verb - 01-05-2018, 03:52 PM
RE: Philco 41-290 - by Raleigh - 01-16-2018, 05:08 PM
RE: Philco 41-290 - by Ron Ramirez - 01-16-2018, 08:53 PM
RE: Philco 41-290 - by verb - 01-16-2018, 10:25 PM
RE: Philco 41-290 - by verb - 01-16-2018, 10:26 PM
RE: Philco 41-290 - by verb - 04-06-2018, 05:55 PM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 4939 online users. [Complete List]
» 3 Member(s) | 4936 Guest(s)
