Signal Injection Question
#35
Well....I took over.
The sch seems to be the same as 46-250. Same tubes and seens to be same everything else.
So. Tonight I triedto inject the IF through.
I shorted the points where the loop antenna is connected.
The IF is tuned to.....625kHz. not 455kHz. Hence the problems. Oh....and the gain is low.
So I'll have to figure out why it is.
Rich,
When you said the IF passed through, what frequency was it? You said 455kHz but it does not react to it.
Signal Injection Question - by Welder - 12-24-2017, 06:02 AM
RE: Signal Injection Question - by Phlogiston - 12-24-2017, 11:13 AM
RE: Signal Injection Question - by Welder - 12-24-2017, 11:51 AM
RE: Signal Injection Question - by Phlogiston - 12-24-2017, 12:00 PM
RE: Signal Injection Question - by morzh - 12-24-2017, 12:07 PM
RE: Signal Injection Question - by Radioroslyn - 12-24-2017, 12:41 PM
RE: Signal Injection Question - by Welder - 12-24-2017, 03:17 PM
RE: Signal Injection Question - by morzh - 12-24-2017, 04:41 PM
RE: Signal Injection Question - by Welder - 12-24-2017, 06:20 PM
RE: Signal Injection Question - by David - 12-24-2017, 10:01 PM
RE: Signal Injection Question - by David - 12-24-2017, 10:12 PM
RE: Signal Injection Question - by morzh - 12-24-2017, 11:45 PM
RE: Signal Injection Question - by Welder - 12-25-2017, 05:49 AM
RE: Signal Injection Question - by Welder - 12-25-2017, 05:54 AM
RE: Signal Injection Question - by morzh - 12-25-2017, 07:41 PM
RE: Signal Injection Question - by Welder - 12-25-2017, 10:25 PM
RE: Signal Injection Question - by morzh - 12-25-2017, 10:37 PM
RE: Signal Injection Question - by Welder - 12-26-2017, 07:12 AM
RE: Signal Injection Question - by morzh - 12-26-2017, 11:59 AM
RE: Signal Injection Question - by Welder - 12-26-2017, 09:50 PM
RE: Signal Injection Question - by morzh - 12-26-2017, 10:33 PM
RE: Signal Injection Question - by Radioroslyn - 12-27-2017, 01:08 AM
RE: Signal Injection Question - by Welder - 12-27-2017, 07:10 AM
RE: Signal Injection Question - by morzh - 12-27-2017, 10:23 AM
RE: Signal Injection Question - by Welder - 12-27-2017, 01:37 PM
RE: Signal Injection Question - by oldswab37 - 12-27-2017, 04:37 PM
RE: Signal Injection Question - by Welder - 12-27-2017, 06:04 PM
RE: Signal Injection Question - by morzh - 12-27-2017, 06:09 PM
RE: Signal Injection Question - by Welder - 12-27-2017, 07:47 PM
RE: Signal Injection Question - by morzh - 12-28-2017, 01:02 AM
RE: Signal Injection Question - by Welder - 12-28-2017, 05:19 AM
RE: Signal Injection Question - by morzh - 12-28-2017, 12:56 PM
RE: Signal Injection Question - by morzh - 01-03-2018, 10:10 PM
RE: Signal Injection Question - by Welder - 01-04-2018, 05:51 AM
RE: Signal Injection Question - by morzh - 01-04-2018, 02:50 PM
RE: Signal Injection Question - by Welder - 01-04-2018, 06:41 PM
RE: Signal Injection Question - by morzh - 01-04-2018, 06:52 PM
RE: Signal Injection Question - by Welder - 01-08-2018, 05:41 PM
RE: Signal Injection Question - by morzh - 01-08-2018, 05:48 PM
RE: Signal Injection Question - by Welder - 01-08-2018, 07:05 PM
RE: Signal Injection Question - by jcassity - 01-17-2018, 10:07 AM
RE: Signal Injection Question - by morzh - 01-17-2018, 10:53 AM
RE: Signal Injection Question - by jcassity - 01-17-2018, 11:13 AM
RE: Signal Injection Question - by morzh - 01-17-2018, 02:50 PM
Users browsing this thread: 17 Guest(s)
The speaker table error?
Philco 70 antenna lead
There are currently 6708 online users. [Complete List]
» 2 Member(s) | 6706 Guest(s)
