Bakelite block info??
Wayback Machine to the rescue!
https://web.archive.org/web/201603242327...lokcap.htm
I would use 600 or 630V caps to replace every paper capacitor if it were my radio.
Bakelite block info?? - by jeffb - 01-04-2018, 12:29 PM
RE: Bakelite block info?? - by Ron Ramirez - 01-04-2018, 01:20 PM
RE: Bakelite block info?? - by jeffb - 01-04-2018, 05:07 PM
RE: Bakelite block info?? - by Kestas - 01-05-2018, 11:54 AM
RE: Bakelite block info?? - by jeffb - 01-10-2018, 09:17 AM
RE: Bakelite block info?? - by Ron Ramirez - 01-10-2018, 09:24 AM
RE: Bakelite block info?? - by klondike98 - 01-10-2018, 10:24 AM
RE: Bakelite block info?? - by jeffb - 01-10-2018, 10:30 AM
RE: Bakelite block info?? - by Kestas - 01-10-2018, 10:44 AM
The speaker table error?
Philco 70 antenna lead
