Model ID, 70, 90 ?
Hello Bob, and welcome.
You must have a 90 since it has nine tubes. The 56 is a substitute for a 27, and it appears to me that someone substituted 56s for every 27 in your set.
Most likely this schematic will match your set:
http://www.philcoradio.com/images/phorum/schem/90b.jpg
Good luck.
Model ID, 70, 90 ? - by robark - 01-08-2018, 12:59 PM
RE: Model ID, 70, 90 ? - by Ron Ramirez - 01-08-2018, 01:28 PM
RE: Model ID, 70, 90 ? - by robark - 01-08-2018, 01:41 PM
RE: Model ID, 70, 90 ? - by klondike98 - 01-08-2018, 02:10 PM
RE: Model ID, 70, 90 ? - by Radioroslyn - 01-08-2018, 08:43 PM
The speaker table error?
Philco 70 antenna lead
There are currently 6900 online users. [Complete List]
» 2 Member(s) | 6898 Guest(s)
