Bakelite block info??
Hello, I found what I needed here on this wonderful site. Under: Philco restoration notebook, there is a link to the Philco Tech section, a thread labeled "Philco Bakelite block condenser data, then Ron put a link to a PDF file which is an original publication from Philco dated 1937 which lists all old obsolete Bakelite part numbers (all of mine in question are there Icon_smile) and a suitable replacement part number. Thanks a lot!!
http://philcoradio.com/phorum/attachment.php?aid=10650 here is the link to the pdf
Bakelite block info?? - by jeffb - 01-04-2018, 12:29 PM
RE: Bakelite block info?? - by Ron Ramirez - 01-04-2018, 01:20 PM
RE: Bakelite block info?? - by jeffb - 01-04-2018, 05:07 PM
RE: Bakelite block info?? - by Kestas - 01-05-2018, 11:54 AM
RE: Bakelite block info?? - by jeffb - 01-10-2018, 09:17 AM
RE: Bakelite block info?? - by Ron Ramirez - 01-10-2018, 09:24 AM
RE: Bakelite block info?? - by klondike98 - 01-10-2018, 10:24 AM
RE: Bakelite block info?? - by jeffb - 01-10-2018, 10:30 AM
RE: Bakelite block info?? - by Kestas - 01-10-2018, 10:44 AM
The speaker table error?
Philco 70 antenna lead
