Model 70
Skip, here's a thread on how I did my Sprague caps. I ground off the bottom crimp and pulled the guts out the bottom. In your case, that's not really an option any more but maybe it will give you some ideas. If I recall correctly I think Phlogiston has also soldered this type of cap back together and then smoothed the joint ....
Model 70 - by vecher - 11-29-2017, 09:41 PM
RE: Model 70 - by Ron Ramirez - 11-29-2017, 10:33 PM
RE: Model 70 - by vecher - 12-02-2017, 01:55 AM
RE: Model 70 - by Arran - 12-02-2017, 03:46 AM
RE: Model 70 - by Steve Davis - 12-02-2017, 08:53 AM
RE: Model 70 - by vecher - 12-02-2017, 02:30 PM
RE: Model 70 - by vecher - 12-02-2017, 04:40 PM
RE: Model 70 - by vecher - 12-03-2017, 11:23 AM
RE: Model 70 - by morzh - 12-03-2017, 12:20 PM
RE: Model 70 - by vecher - 12-25-2017, 12:40 AM
RE: Model 70 - by AudreyHepburn - 12-29-2017, 11:14 PM
RE: Model 70 - by vecher - 12-29-2017, 11:59 PM
RE: Model 70 - by Radioroslyn - 12-30-2017, 12:36 AM
RE: Model 70 - by TV MAN - 12-30-2017, 11:30 PM
RE: Model 70 - by vecher - 12-31-2017, 02:19 AM
RE: Model 70 - by vecher - 01-07-2018, 12:17 AM
RE: Model 70 - by klondike98 - 01-07-2018, 09:16 AM
RE: Model 70 - by Steve Davis - 01-07-2018, 10:46 AM
RE: Model 70 - by Ron Ramirez - 01-07-2018, 10:52 AM
RE: Model 70 - by vecher - 01-07-2018, 12:53 PM
RE: Model 70 - by vecher - 01-10-2018, 12:15 PM
RE: Model 70 - by Steve Davis - 01-10-2018, 12:36 PM
RE: Model 70 - by klondike98 - 01-10-2018, 01:07 PM
RE: Model 70 - by vecher - 01-10-2018, 02:08 PM
RE: Model 70 - by morzh - 01-10-2018, 05:05 PM
RE: Model 70 - by klondike98 - 01-10-2018, 06:25 PM
RE: Model 70 - by Warren - 01-10-2018, 09:17 PM
RE: Model 70 - by vecher - 01-11-2018, 12:59 AM
RE: Model 70 - by vecher - 01-11-2018, 01:12 AM
RE: Model 70 - by Steve Davis - 01-11-2018, 02:00 AM
RE: Model 70 - by morzh - 01-11-2018, 09:36 AM
RE: Model 70 - by vecher - 01-13-2018, 08:18 PM
RE: Model 70 - by vecher - 01-13-2018, 08:21 PM
RE: Model 70 - by vecher - 01-17-2018, 12:13 AM
RE: Model 70 - by vecher - 01-20-2018, 09:17 PM
RE: Model 70 - by Steve Davis - 01-21-2018, 12:07 AM
RE: Model 70 - by EdHolland - 01-21-2018, 03:33 AM
RE: Model 70 - by Steve D - 01-21-2018, 11:49 AM
RE: Model 70 - by vecher - 01-21-2018, 02:22 PM
RE: Model 70 - by vecher - 01-21-2018, 06:02 PM
RE: Model 70 - by vecher - 01-22-2018, 12:02 AM
RE: Model 70 - by vecher - 01-22-2018, 09:47 PM
RE: Model 70 - by vecher - 01-28-2018, 11:25 PM
RE: Model 70 - by mg34.42 - 03-18-2018, 03:32 PM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 4954 online users. [Complete List]
» 1 Member(s) | 4953 Guest(s)
