Bakelite block condensers
Hi Exray
Model 70 (early) inside the grandfather clock (570)
My diagram escapes me (in my mess) right now.
Block has a .09mf cap and a 250 ohm resistor.
Tim
Bakelite block condensers - by TimC - 04-23-2010, 05:17 PM
Re: Bakelite block condensers - by exray - 04-23-2010, 05:23 PM
Re: Bakelite block condensers - by TimC - 04-23-2010, 05:34 PM
Re: Bakelite block condensers - by denver - 04-23-2010, 06:51 PM
Re: Bakelite block condensers - by exray - 04-24-2010, 12:06 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
