1934/35 Radio Question
I think that one of the control connections [volume and tuning] in the model N is female, both male in FT-6.
you can also compare schematics.  one for the model N is in the may-june ford service bulletin, pg 192, the FT-6 on line at http://www.nostalgiaair.org/pagesbymodel...014014.pdf
 at the least, you can compare the FT-6 pictures on line to your radio. in particular, check the location of the output transformer, part no. 46. in the FT-6, it's bolted to a vertical plate right in the middle of the radio. in the model N, it's bolted to a horizontal plate beside the vibrator on the tube side of the radio.
 good luck.
1934/35 Radio Question - by jim eubanks - 07-14-2017, 11:43 AM
RE: 1934/35 Radio Question - by fenbach - 01-11-2018, 12:50 AM
1934/35 Radio Question - by klondike98 - 07-14-2017, 02:02 PM
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 5505 online users. [Complete List]
» 3 Member(s) | 5502 Guest(s)
