A Model 16X story
#42
Last evening, I got under the chassis and straightened out the wiring issues at the filter block cap. Things now match the wiring diagram on my service sheet, and trace correctly to their respective parts of the circuit.
I'm not sure this explains why signal was not making it through the 77 pentode before the power stage, but will check voltages etc. in the next work session. Wiring from the volume control, power and grid connections look to be correct, but check and recheck always helps.
I'd hit a bit of a nervous dither a couple of weeks ago, but enthusiasm for this radio is really picking up again Icon_smile
A Model 16X story - by EdHolland - 11-26-2017, 09:32 PM
RE: A Model 16X story - by morzh - 11-26-2017, 09:50 PM
RE: A Model 16X story - by VntgRads - 11-27-2017, 02:39 AM
RE: A Model 16X story - by EdHolland - 11-27-2017, 03:16 PM
RE: A Model 16X story - by EdHolland - 11-27-2017, 03:37 PM
RE: A Model 16X story - by EdHolland - 11-27-2017, 06:18 PM
RE: A Model 16X story - by EdHolland - 11-27-2017, 09:15 PM
RE: A Model 16X story - by sam - 11-28-2017, 12:59 PM
RE: A Model 16X story - by EdHolland - 11-28-2017, 01:46 PM
RE: A Model 16X story - by EdHolland - 11-28-2017, 02:04 PM
RE: A Model 16X story - by EdHolland - 11-28-2017, 02:38 PM
RE: A Model 16X story - by morzh - 11-28-2017, 03:08 PM
RE: A Model 16X story - by EdHolland - 11-28-2017, 03:21 PM
RE: A Model 16X story - by morzh - 11-28-2017, 05:49 PM
RE: A Model 16X story - by EdHolland - 11-28-2017, 08:18 PM
RE: A Model 16X story - by EdHolland - 11-29-2017, 01:23 PM
RE: A Model 16X story - by EdHolland - 11-29-2017, 01:29 PM
RE: A Model 16X story - by klondike98 - 11-29-2017, 01:53 PM
RE: A Model 16X story - by morzh - 11-29-2017, 02:13 PM
RE: A Model 16X story - by EdHolland - 11-29-2017, 02:43 PM
RE: A Model 16X story - by morzh - 11-29-2017, 03:40 PM
RE: A Model 16X story - by EdHolland - 11-29-2017, 04:22 PM
RE: A Model 16X story - by morzh - 11-29-2017, 05:14 PM
RE: A Model 16X story - by Ron Ramirez - 11-29-2017, 06:46 PM
RE: A Model 16X story - by EdHolland - 11-29-2017, 07:26 PM
RE: A Model 16X story - by Ron Ramirez - 11-29-2017, 10:28 PM
RE: A Model 16X story - by EdHolland - 11-29-2017, 11:08 PM
RE: A Model 16X story - by Steve Davis - 11-29-2017, 11:17 PM
RE: A Model 16X story - by Electrothaumaturgist - 11-29-2017, 11:26 PM
RE: A Model 16X story - by EdHolland - 12-04-2017, 03:46 PM
RE: A Model 16X story - by EdHolland - 12-08-2017, 03:55 PM
RE: A Model 16X story - by EdHolland - 12-11-2017, 01:39 PM
RE: A Model 16X story - by EdHolland - 12-23-2017, 09:47 PM
RE: A Model 16X story - by EdHolland - 12-26-2017, 10:55 PM
RE: A Model 16X story - by Brad Winder - 12-27-2017, 12:18 AM
RE: A Model 16X story - by Ron Ramirez - 12-27-2017, 12:23 PM
RE: A Model 16X story - by EdHolland - 12-27-2017, 11:46 PM
RE: A Model 16X story - by EdHolland - 12-31-2017, 12:47 PM
RE: A Model 16X story - by EdHolland - 12-31-2017, 05:50 PM
RE: A Model 16X story - by EdHolland - 01-06-2018, 10:29 PM
RE: A Model 16X story - by EdHolland - 01-07-2018, 11:43 PM
RE: A Model 16X story - by EdHolland - 01-11-2018, 01:36 PM
RE: A Model 16X story - by EdHolland - 01-12-2018, 06:13 PM
RE: A Model 16X story - by EdHolland - 01-14-2018, 08:21 PM
RE: A Model 16X story - by morzh - 01-14-2018, 08:53 PM
RE: A Model 16X story - by EdHolland - 01-15-2018, 02:22 PM
RE: A Model 16X story - by morzh - 01-15-2018, 02:26 PM
RE: A Model 16X story - by EdHolland - 01-17-2018, 12:59 PM
RE: A Model 16X story - by EdHolland - 01-19-2018, 07:58 PM
RE: A Model 16X story - by EdHolland - 01-20-2018, 10:46 PM
RE: A Model 16X story - by 462ron - 01-21-2018, 01:47 PM
RE: A Model 16X story - by EdHolland - 01-21-2018, 10:39 PM
RE: A Model 16X story - by 462ron - 01-22-2018, 01:14 AM
RE: A Model 16X story - by EdHolland - 04-02-2018, 02:06 PM
RE: A Model 16X story - by gregb - 04-02-2018, 03:47 PM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 2633 online users. [Complete List]
» 2 Member(s) | 2631 Guest(s)
