1941 Ford car Philco model F-1841
Check across 7C5 pins 1 and 8 should see 6vdc. Remove 7C5 and check the resistance from pins 1 to 8 at the bottom of the tube should see a few ohms. If that checks out check the other voltages on the 7C5 w/tube in place and set on.
Pin 1 0v
Pin 2 several hundred volts
Pin 3 several hundred volts
Pin 6 -7vdc or so
Pin 7 +7vdc or so
Pin 8 +6vdc
1941 Ford car Philco model F-1841 - by flatheadjr - 12-12-2017, 12:00 PM
RE: 1941 Ford car Philco model F-1841 - by Radioroslyn - 01-12-2018, 10:49 PM
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 9725 online users. [Complete List]
» 2 Member(s) | 9723 Guest(s)
