Take a look! Model 144B Cathedral
That looks very nice Ron. I don't do much refinishing as it take me a long time, but they usually turn out nice. I think I would be making about 25 cents an hour!
Re: Take a look! Model 144B Cathedral - by TimC - 05-19-2010, 09:02 AM
Re: Take a look! Model 144B Cathedral - by vinzer - 05-19-2010, 12:25 PM
Re: Take a look! Model 144B Cathedral - by hotrod - 05-19-2010, 05:44 PM
Re: Take a look! Model 144B Cathedral - by denver - 05-19-2010, 07:29 PM
Re: Take a look! Model 144B Cathedral - by Uffda - 05-20-2010, 03:12 PM
Re: Take a look! Model 144B Cathedral - by Jim Berg - 05-26-2010, 09:37 PM
Re: Take a look! Model 144B Cathedral - by Arran - 01-31-2012, 02:35 AM
Re: Take a look! Model 144B Cathedral - by Jayce - 01-31-2012, 11:51 AM
Re: Take a look! Model 144B Cathedral - by kg4wpt - 02-05-2012, 04:33 PM
Philco 91 Tuning Condenser
There are currently 4972 online users. [Complete List]
» 2 Member(s) | 4970 Guest(s)
