Proper hookup wire to use
Don't about the others here but I get mine from Radio Daze. I buy the small profile wire 20 AWG. I use the solid if the wire is not going to be moved or bent as inside the chassis. Never bought any Chinese made wire so can't comment on its quality.
Proper hookup wire to use - by murf - 01-13-2018, 09:18 PM
RE: Proper hookup wire to use - by KCMike - 01-13-2018, 09:56 PM
RE: Proper hookup wire to use - by Brad Winder - 01-14-2018, 03:56 AM
RE: Proper hookup wire to use - by Brad Winder - 01-14-2018, 04:07 AM
RE: Proper hookup wire to use - by jcassity - 01-14-2018, 12:23 PM
RE: Proper hookup wire to use - by Eliot Ness - 01-15-2018, 03:22 PM
New member
Hello jeff, Welcome aboard ! Sincerely Riochardradiorich — 06:53 PM
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4817 online users. [Complete List]
» 3 Member(s) | 4814 Guest(s)
