Philco 86 restoration
#41
Well,
When I put everything in the cabinet, the hum became really pronounced.
This is the hum that is independent of the volume.
I put it back on the bench, and traced the hum to the 1st AF driver, a 26 tube.
Pulled out, the hum stops.
Shorted to GND with a wire or a cap grid when in also stops the hum.
The suspect: the Interstage transformer between the detector and the AF. The output windng ohms out at 6,000 Ohms.
Questions: 1. Has anyone else experienced the hum problem, 2. Is the 6,000 ohm the right resistance for the interstage xfmr secondary? The one mentioned before.
Philco 86 restoration - by morzh - 12-22-2017, 03:52 PM
RE: Philco 86 restoration - by Ron Ramirez - 12-22-2017, 04:23 PM
RE: Philco 86 restoration - by KCMike - 12-22-2017, 04:35 PM
RE: Philco 86 restoration - by Radioroslyn - 12-22-2017, 04:47 PM
RE: Philco 86 restoration - by morzh - 12-22-2017, 05:41 PM
RE: Philco 86 restoration - by morzh - 12-22-2017, 07:25 PM
RE: Philco 86 restoration - by Ron Ramirez - 12-22-2017, 09:15 PM
RE: Philco 86 restoration - by morzh - 12-22-2017, 10:16 PM
RE: Philco 86 restoration - by morzh - 12-22-2017, 10:48 PM
RE: Philco 86 restoration - by morzh - 12-22-2017, 10:50 PM
RE: Philco 86 restoration - by morzh - 12-23-2017, 11:12 PM
RE: Philco 86 restoration - by morzh - 12-23-2017, 11:38 PM
RE: Philco 86 restoration - by morzh - 12-25-2017, 08:31 PM
RE: Philco 86 restoration - by Radioroslyn - 12-25-2017, 11:20 PM
RE: Philco 86 restoration - by morzh - 12-25-2017, 11:57 PM
RE: Philco 86 restoration - by morzh - 12-26-2017, 12:07 AM
RE: Philco 86 restoration - by morzh - 12-26-2017, 02:42 PM
RE: Philco 86 restoration - by Radioroslyn - 12-26-2017, 03:34 PM
RE: Philco 86 restoration - by morzh - 12-26-2017, 03:57 PM
RE: Philco 86 restoration - by Radioroslyn - 12-26-2017, 04:11 PM
RE: Philco 86 restoration - by morzh - 12-26-2017, 04:27 PM
RE: Philco 86 restoration - by morzh - 12-26-2017, 05:47 PM
RE: Philco 86 restoration - by morzh - 12-26-2017, 10:48 PM
RE: Philco 86 restoration - by Ron Ramirez - 12-27-2017, 12:26 PM
RE: Philco 86 restoration - by WyTex - 12-27-2017, 12:37 PM
RE: Philco 86 restoration - by morzh - 12-27-2017, 01:09 PM
RE: Philco 86 restoration - by morzh - 12-28-2017, 07:45 PM
RE: Philco 86 restoration - by EdHolland - 12-28-2017, 11:30 PM
RE: Philco 86 restoration - by morzh - 12-29-2017, 10:03 AM
RE: Philco 86 restoration - by EdHolland - 12-29-2017, 03:21 PM
RE: Philco 86 restoration - by Radioroslyn - 12-29-2017, 03:43 PM
RE: Philco 86 restoration - by morzh - 12-29-2017, 03:51 PM
RE: Philco 86 restoration - by morzh - 12-29-2017, 07:44 PM
RE: Philco 86 restoration - by morzh - 12-30-2017, 07:35 PM
RE: Philco 86 restoration - by morzh - 12-31-2017, 08:38 PM
RE: Philco 86 restoration - by morzh - 12-31-2017, 08:59 PM
RE: Philco 86 restoration - by morzh - 01-01-2018, 05:32 PM
RE: Philco 86 restoration - by Radioroslyn - 01-01-2018, 05:54 PM
RE: Philco 86 restoration - by morzh - 01-01-2018, 06:31 PM
RE: Philco 86 restoration - by morzh - 01-01-2018, 08:00 PM
RE: Philco 86 restoration - by morzh - 01-13-2018, 10:58 PM
RE: Philco 86 restoration - by morzh - 01-14-2018, 11:26 AM
RE: Philco 86 restoration - by morzh - 01-14-2018, 09:07 PM
RE: Philco 86 restoration - by morzh - 01-14-2018, 10:41 PM
RE: Philco 86 restoration - by morzh - 01-15-2018, 08:42 PM
RE: Philco 86 restoration - by morzh - 01-17-2018, 12:15 AM
RE: Philco 86 restoration - by morzh - 01-17-2018, 09:33 AM
RE: Philco 86 restoration - by morzh - 01-18-2018, 10:41 PM
RE: Philco 86 restoration - by Arran - 01-19-2018, 12:47 AM
RE: Philco 86 restoration - by morzh - 01-19-2018, 09:14 AM
The speaker table error?
Philco 70 antenna lead
There are currently 5882 online users. [Complete List]
» 1 Member(s) | 5881 Guest(s)
