Model 41-290 dial stringing help
Thank you very much!
Model 41-290 dial stringing help - by gcerio - 01-14-2018, 04:27 PM
RE: Model 41-290 dial stringing help - by gcerio - 01-14-2018, 04:52 PM
The speaker table error?
Philco 70 antenna lead
