37-650 Issues
When I injected the signal into the volume control, I heard it through the speaker, and the control did vary the sound. There are three terminals on top- one goes to ground, at the chassis, then on to the #3 position for the antenna connections. I tested on the other two. I did not test on the one below...
What should I look for next?
Scott
Old Cars, Old Radios, Old Pipes and Young Women... What more is there?
37-650 Issues - by Robbie Roberts - 01-27-2006, 07:06 AM
[No subject] - by Steve Chambers - 01-27-2006, 08:01 AM
[No subject] - by Robbie Roberts - 01-27-2006, 12:07 PM
[No subject] - by Steve Chambers - 01-27-2006, 12:21 PM
[No subject] - by Robbie Roberts - 01-27-2006, 12:32 PM
[No subject] - by Robbie Roberts - 01-27-2006, 06:02 PM
[No subject] - by Steve Chambers - 01-27-2006, 06:23 PM
[No subject] - by Robbie Roberts - 01-27-2006, 06:29 PM
[No subject] - by Steve Chambers - 01-27-2006, 06:38 PM
[No subject] - by Robbie Roberts - 01-27-2006, 06:41 PM
[No subject] - by Robbie Roberts - 01-27-2006, 06:51 PM
[No subject] - by Steve Chambers - 01-27-2006, 07:05 PM
[No subject] - by Robbie Roberts - 01-27-2006, 07:44 PM
[No subject] - by Robbie Roberts - 01-27-2006, 09:07 PM
[No subject] - by Robbie Roberts - 01-30-2006, 05:12 PM
[No subject] - by Chuck Schwark - 01-30-2006, 07:53 PM
[No subject] - by Steve Chambers - 01-30-2006, 07:59 PM
[No subject] - by Robbie Roberts - 01-30-2006, 08:02 PM
[No subject] - by Chuck Schwark - 01-30-2006, 08:12 PM
[No subject] - by Robbie Roberts - 01-31-2006, 12:52 AM
[No subject] - by Chuck Schwark - 01-31-2006, 09:57 AM
[No subject] - by Robbie Roberts - 01-31-2006, 11:43 AM
[No subject] - by Robbie Roberts - 01-31-2006, 06:40 PM
[No subject] - by Steve Chambers - 01-31-2006, 08:53 PM
[No subject] - by Robbie Roberts - 02-02-2006, 09:24 AM
[No subject] - by Steve Chambers - 02-02-2006, 05:00 PM
[No subject] - by Chuck Schwark - 02-02-2006, 05:47 PM
[No subject] - by Robbie Roberts - 02-02-2006, 06:24 PM
[No subject] - by Chuck Schwark - 02-02-2006, 07:42 PM
[No subject] - by Robbie Roberts - 02-02-2006, 07:43 PM
[No subject] - by Robbie Roberts - 02-02-2006, 08:36 PM
[No subject] - by Chuck Schwark - 02-02-2006, 10:22 PM
[No subject] - by Robbie Roberts - 02-02-2006, 11:03 PM
[No subject] - by Bill Hutchinson - 02-03-2006, 03:20 PM
[No subject] - by Robbie Roberts - 02-03-2006, 03:26 PM
[No subject] - by Bill Hutchinson - 02-03-2006, 07:08 PM
[No subject] - by Robbie Roberts - 02-04-2006, 08:29 AM
[No subject] - by Robbie Roberts - 02-05-2006, 01:42 AM
[No subject] - by 49Stude63 - 02-05-2006, 11:07 AM
Philco 91 Tuning Condenser
There are currently 10071 online users. [Complete List]
» 1 Member(s) | 10070 Guest(s)
